Polyline to Circle
5691
02-20-2015 12:50 AM
ChittayongSurakitbanharn
I have a layer of 120 polylines created from XY coordinates of start and end points.  I now would like to create a layer of circles (polylines not polygons) with one end point of each polyline as the center and the other end point of the polyline as the outer radius.
How do I do this?
Thanks!
JayantaPoddar
You could follow the following workflow.
1) Add 3 fields to the polyline layer, viz., Length (in meters), Start_X (X Coordinate/Longitude of Starting point), and Start_Y (Y Coordinate/Latitude of Starting point) using Calculate Geometry in the attribute table.
2) Export the attribute table to a table file (e.g. *.dbf)
3) In ArcCatalog, create XY point feature class from the above table file. Define a GCS spatial reference.
4) Reproject the shapefile to a projected coordinate system (e.g. UTM).
5) Use Buffer (Analysis) tool to build the Circles, as desired.
Note: We are reprojecting the points to PCS, so that the buffer takes up linear units (meters) and not angular units (Degree Decimal).
I hope it solves your issue.
Jay
Think Location
JayantaPoddar
Jay
Think Location
JayantaPoddar
Forgot to add my output snapshot!!!
Think Location
Extremely helpful!  Thanks Jay!
