Polygons Boundaries
1432
08-02-2011 06:53 AM
Pierre-LucBoivin
I would like to create boundaries from a polyline shapefile and have only the exterior limit of this area. I made a buffer to convert my polyline to polygon but I'm not able to clean all the holes and gaps in it.
I've try many apps like Hawth's Tool, Et GEoWizard but I didn't found the function to be able to do what I want. The only extensions I have is Network Analyst
Here some screenshots of my steps and the result I'd like to have.
Thanks for your help
DanLee
by Esri Regular Contributor
If you have ArcGIS 10 and an ArcInfo license, you can try the Eliminate Polygon Part tool (Data Management toolbox - Features toolset), which allows you to remove contained parts/holes.
Also, Feature To Polygon tool (Data Management toolbox - Features toolset) produces polygons from lines and/or polygons. Since your final polygons represent some classifications, you can try the following:
1. Select the lines or buffer polygons of the same class;
2. Run Feature To Line to get polygons (spaces surrounded by lines or polygons will become polygons);
3. Run Dissolve tool to remove interior boundaries.
4. Repeat 1 - 3 for each class. Then Merge or Append them together.
It might be necessary to write a script or build a model to do this in a loop/iteration. You may still end up having holes/spaced between classes. I am not sure which class those spaces should belong to. You will need sort that out.
Hope the above helps to some degree.
Regards,
