merging multiple polylines from different layer
2839
07-30-2011 08:48 AM
jerryjones
I am trying to find a simple way in which to merge a large number of polylines from a number of layers to form one polygon feature using arc10. Is there a simple solution to this...
thanks
jerry
DanLee
by Esri Regular Contributor
You can check if Feature To Polygon tool works for your case. You can either run this tool to get polygons for each polyline layer and then Merge or Append them; or get polygons from multiple layers at once.
Regards,
