Ploygon clipping problem
1424
11-02-2013 09:56 AM
MauricioPorte
So I select the top polygon, choose clip from the editor drop down menu, and chose discard intersection. The results are not what I expect: [ATTACH=CONFIG]28825[/ATTACH][ATTACH=CONFIG]28826[/ATTACH]
LeonardLuz3
Hi there mau! Can you provide specific details on what do you want to achieve with your data? It's quite hard to answer your question with just the given info. 🙂
by Anonymous User
Not applicable
Original User: mauporte
I just wanted to clip one polygon using the other polygon.
I fixed it by converting the shapefile to cad and then reconverting the dwg to shp. After doing so, I was able to use the clipping tool without the intersecting polygons disappearing.
