Please help - Arc GIS Question
7440
9
11-30-2014 10:31 PM
desiraecole
I am having serious trouble with a geodatabase assignment. The assignment requires us to go to a park, locate thrity something points by longitude and latitude, and then plot them on a map in ArcMap 10.2. However, I was sent a file to use, I believe it contains metadata as each file contains an extension like .atx, .gdbtablx, .spx, etc. When I try to connect to the folder in ArcCatalog, it doesn't even show up as visible. I've also tried connecting to the folder through ArcMap, and even dragging and dropping. How do I use this information in ArcMap?
Any suggestion is welcome, and thank you in advance!!!!
JakeSkinner
Esri Esteemed Contributor
Hi Desirae,
It appears you are trying to use a File Geodatabase.  These files should be within a folder with a .gdb extension.  Could you send a screen shot of how the data appears in Windows Explorer?
desiraecole
Hi Jake,
Thank you so much for your response! Here's a screenshot of the folder. There are other files that are not shown, but they all follow a similar format.
JakeSkinner
Yes, this is a file geodatabase.  Copy the 'New File Geodatabase.gdb' to a directory, i.e. 'C:\temp'.  Then, in the Catalog window, you should see the geodatabase:
desiraecole
would it be okay if you walked me through this over the phone? I am truly having a difficult time getting my data to show up
JakeSkinner
Tech Support will be able to.  You can call them at 888-377-4575 and log an incident.
desiraecole
thank you!
desiraecole
I do have another question for you. So, is the geodatabase folder that I have ready to be used in ArcMap? Do I have to use it in ArcCatalog first? If I finally do get it to show up in ArcCatalog, then do I create feature classes and all of that? I just want to make sure that I'm not giving myself extra work. My only objective is to make a map. My professor sent me that Geodatabase file, and I am really at a lost for what to do with it.
desiraecole
thank you so much, it worked!!!
TimWitt2
Don't forget to mark Sol's answer as correct!
