Hi
I have seen a few posts with requests for help with this, and because no one appears to have answered the posts conclusively, I'm wondering if any of the previous guys that posted found a way to set this up. I'm trialing a high availability database setup using Oracle RAC and ArcSDE 9.3.1 on Windows 2008 64-bit on vmware and ASM on SAN.
We have the RAC up and running with two nodes and failover, loadbalancing working fine. I need to install SDE (Direct Connect and SDE Three Tier on another application server) and I'm not sure how to complete this.
My initial thoughts on this are:
1. Install SDE on Node 1
2. Run post install to create SDE repository and schema on database
3. configure SDE (in the past I start SDE, use the commands I'm familiar with and then shut down the service).
4. Install SDE on Node 2, but not do any post install.
5. Install client on Desktop, setup TNS and direct connect to RAC
6. To complete the three tier connection on another application server:
install SDE on server
What next??
Any help with verifying these steps and or provide more information will be greatly appreciated. Most of the documentation refered to in other posts do not provide this step by step approach.
Joseph
