My Identify's Location show wrong coordinates ?
3576
04-27-2018 08:29 AM
DEAF_PROBERT_68
Honored Contributor
I just discovered thht my Location in the Identify dialog box  had the wrong UTM. It says it is 13S but I am working on 13N because all of my data are suppose to be in NAD 1983 UTM Zone 13 N.
Why does it show up as 13S instead of 13N ???
How do I fix the problem ?
Thanks
DanPatterson_Retired
check the map... that is the true utm system and it allows you to narrow your location down to one 6 degree x 8 degree block of longitude and latitude
You may consider this old school, but the 'current' division of splitting utm zones into the (N)orthern  and (S)outhern hemisphere is 'relatively' new.
AbdullahAnter
Honored Contributor
Could you attach screenshot for the projection of data frame and another one for the feature class.
DEAF_PROBERT_68
Honored Contributor
Sure !
You aren't in the southern hemisphere you are in utm zone 13S
https://en.wikipedia.org/wiki/Universal_Transverse_Mercator_coordinate_system#/media/File:Utm-zones....
Don't confuse S with S as in the first S is the utm zone grid designator and the generic S is a simplified variant for N or S
Clear???/
DEAF_PROBERT_68
Honored Contributor
So it is correct that it is as in the  "Grid"  shows 13 S ?
I see.
