mxdperfstat issues MxdRefreshTimer error
3844
5
11-06-2014 06:18 AM
TerryIffland
I'm trying to run mxdperfstat10 and get the error "MxdRefreshTimer has stopped working". I've searched and cannot find anything on this topic.
Is anyone else getting this error and were you able to resolve it?
Problem Details:
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: mxdperfstat10.exe
  Application Version: 1.0.0.0
  Application Timestamp: 4c48d75c
  Fault Module Name: KERNELBASE.dll
  Fault Module Version: 6.1.7601.18409
  Fault Module Timestamp: 53159a86
  Exception Code: e0434f4d
  Exception Offset: 0000c42d
  OS Version: 6.1.7601.2.1.0.256.4
  Locale ID: 1033
I am running ArcGIS for Desktop 10.1 SP1 on a machine with 64-bit Windows 7 Enterprise SP1.
JoshuaBixby
MVP Esteemed Contributor
mxdperfstat on ArcGIS.com.  Download the ZIP file and there is a version of the program for each ArcGIS version.
JoshuaBixby
From what you have provided, it looks like you may be using the wrong version.  If you are running ArcGIS Desktop 10.1 SP1, try running mxdperfstat10.1.exe instead of mxdperfstat10.exe.
TerryIffland
Is there a 10.1 version? If so, where is it located as I've not been able to find it.
JoshuaBixby
TerryIffland
I was able to download and run this. Thanks for the help.
I would not have thought to look in ArcGIS.  How were you able to locate this?  Is there a specific area I need to search?
JoshuaBixby
I have engaged with the developer in the past to sort out some issues with it.  I can't recall how I first found it.  I just did a Google search on "mxdperfstat 10.2" (the 10.2 being important), and the second hit is to ArcGIS.com.  The same search with 10.1 didn't yield as good of results.
When it comes to ArcGIS tools and scripts, I have always found it frustrating how scattered they are under different sites and even domains.  I have found using Google with its site: operator as being most useful.  I have read that Esri is near deploying a new site for scripts and tools, hopefully it will be better than our current situation.
