Moving Mosaic Dataset - Doubt
1742
11-20-2012 09:51 AM
VikramS
Hello ,
I am going to move over my mosaic Dataset from a location (named C:\temp) to another Location D:\Temp . Source images will also gets transferred to D:\Temp and .Overviews folder as Well . All the data from C:\\Temp will be deleted
Will i be able to see my image if i drag the mosaic dataset into ArcMap ??
Is the Overviews referencing to Source Folder or Destination Folder . How can I check that ? HOw to check the path of the images in the mosaic datasets ?
MathewCoyle
Honored Contributor
If you are changing the location of the source rasters you will need to update your mosaic dataset with that new location.
http://resources.arcgis.com/en/help/main/10.1/index.html#//009t0000005m000000
VikramS
I had a question .. If I have the source data in C:\Temp . Create Mosaic Dataset . Build Boundary , Overviews
Moving the source image into D:\Temp and also the mosaic dataset .. Now How to update the mosaic dataset source images path as well as update the overview path
MathewCoyle
Honored Contributor
The overviews should be a relative path so they should be ok. To update the source data path in a mosaic dataset in ArcCatalog right click on your mosaic dataset and click "Repair".
