Labeling Expression Error???
1047
11-16-2012 04:29 AM
KyleLeathers
I am trying to label some roads with a simple expression and I keep getting a "The expression contains an error. Modify the expression and try again" alert. I am only trying to label a "NAME" field and a "TYPE" field. I can't for the life of me figure out what the error is since I have used the expression many times before on different installations/versions. I am currently using ArcMap 10. The expression syntax I am using is:
[NAME] & " " & [TYPE]
Is there something going on with the application itself?
Please help.
AlexeyTereshenkov
Hi Kyle,
1) Where is your data stored - personal/file/SDE geodatabase?
2) Make sure you have VBScript chosen as the Parser in the Label Expression window. Using JScript would result in the error message you have.
KyleLeathers
I get the errors with any files that I try the expressions on. I have tried both VB and JScript in multiple environments with no success. I have come across quite a few problems with this install. I will be getting either a fresh install tomorrow or a PC with with no apparent glitches. Hopefully that will fix the problem. If not, I will be back.
