MODIS Import Tool for ArcGIS
1633
12-18-2011 03:57 PM
DonStazic
This seems to be one of those 'what simple thing am I doing wrong' type of a problem.
I'm trying to use the MODIS Import Tool for ArcGIS.
Looking at the messages from my processing a MODIS tile has been intersected using my boundary.
It then gets the error - "Error downloading images. Note: This is sometimes due to imagery source issues. Please try again shortly"
This problem keeps recurring.
The tool is found at   http://www.pecad.fas.usda.gov/cropexplorer/modis_import_tool.cfm
If you have any ideas, your thoughts would be appreciated.
Cheers,
Don
Luke_Pinner
MVP Regular Contributor
Does your internet connection pass through a proxy that requires authentication?  The MODIS Import Tool uses the python urllib module to download the images. The urllib documentation notes that:
Proxies which require authentication for use are not currently supported; this is considered an implementation limitation.
DonStazic
Thanks Luke. I'll have to check but it sounds likely - Don
