Mass Update Attribute Table Rows
14151
15
01-25-2018 02:45 PM
ZhanShi
Hi~ Everyone,
I want to mass update existing 3,000 rows in attribute table using an excel table without deleting the geometry. Any tools or methods can do that?
Thank you
AdrianWelsh
MVP Honored Contributor
Xander,
Maybe I should explain more about the python script listed above.
I have a set of parcels with different attributes that need to be updated weekly. The engineer has an excel sheet, that I initially generated from the attribute table, that he updates various fields for each parcel of land. To uniquely identify each land parcel, I have to match up two attributes. What the python script does is, see if the two attributes match up, then use an update cursor to change the fields.
I use a CSV file since I get an excel file each week and just save it as a CSV and run it from there. Now, I do not know enough about python and other such things to make it more efficient but this works for me. I am not sure if it would be speedier to take the excel table to a geodatabase each time versus just a CSV since it's normally about 200 records.
So, what I'm saying is, this exact script would not necessarily work for the OP but it's similar to what I use for having to match up two fields (without creating a new field that concatenates the other two, etc.). I hope that makes sense.
ZhanShi
Thank you very much, but I am not familiar with Python script, I have plan to learn more about it.
Lake_Worth_BeachAdmin
excel to table
join table to fc
calculate field using new field in the join
remove join.
AdrianWelsh
Joe, the calculate field thing was mentioned earlier. The OP said:
Because I have 3,000 rows with 20+ fields, Calculate Field can not update so many things in one-shot.
ZhanShi
Just an update, finally, I used field calculator to update each filed after joining the two tables. It takes long to calculate 3000+ records, but it works. Thank you for all your input~
AdrianWelsh
I'm glad to hear that using field calculator essentially solved your issues!
