I have problems in adding .grd file into ArcMap 10 while my coworker next to me has no problem. Please see attached files.
I tried to rename the .grd to.asc and then convert it to raster using ArcTool Conversion tool with no luck.
Any clue will help! Thanks.
Winnie
The link opens up but when you try to download the Geosoft it shows 404 page not found.
Amrita.
We have version 10.2 on our desktops and it will not import Geosoft grd files because it is not listed as a recognised rater format on the list (under Customize-ArcMap Options-Raster-Raster Dataset-File Formats) in either Arc or Arc Catalogue (apparently it has to be there and checked in both places?). An old laptop with V10.1 still on it has Geosoft grd listed as a recognised Raster format in it's list and imports the files fine. We have Target loaded and it should be better at loading these files than the Plug-in according to Geosoft. Does anyone know how to add the grd format to the raster list in Arc?
John
