Load Point Feature Class through SQL Insert
4594
10
05-14-2014 08:55 AM
JPMurphy
What I am trying to accomplish:
Being able to automate data loading into a spatial table/feature class so that the data is viewable in the ArcGIS service after loading.  I know how to do this with just a SQL table with a geometry column but am wanting to make sure it is ok to do once registered with the geodatabase.
When reviewing the documentation about registering it says that you can specify an existing integer field to be the ObjectID field and that from then on the database manages the field starting at the highest integer + 1.  If I don't want to use arcobjects to load the data but instead use a sql insert statement is there a problem if a) I increment the objected field my self or b) specify the objected field to be an identity field and let sql auto increment it?
This data does not need to be versioned or edits tracked.
Is this the right way or am I missing something in the documentation to do this.  I have attempted this in a test environment and either option a or b above seem to work, but I wanted to see if there are any pitfalls to doing it this way.
Thanks!
CherylCleghorn
In terms of the publishing, was it an analyzer warning that you got saying 'Layer's data source is not registered with the server and data will be copied'? If so then you can register your connection with the server to directly access the data source. Server uses either a managed or registered data store:Determining how the server will access service data, About registering your data with the server and Registering a SQL Server database with the server. I am not sure if you are using SQLServer but you can navigate to the relevant link.
Cheryl
