Joining data from zips and counties
3011
03-18-2016 11:25 AM
ChaseBergklint1
I have a project that I am working on that is looking at alumni from my school. I have the number of alumni per zip code but I would like to analyze it also by county. How can I do this?
Tags (1)
DanPatterson_Retired
are the zips fully contained within the county?  If so you could summarize the zip data and join the resultant to the county file.  You might have to use a spatial join if you don't have a common attribute field.
ChaseBergklint1
No, they are not. I have the counties and zip codes as two different shapefiles.
spatial join then
