issue with borders at different scales of mosaic dataset
5035
12
04-26-2018 12:42 PM
bobcostanza
I mosaiced scanned slides/photographs by creating a mosaic data set within a file geodatabase. Besides the result looking pretty ugly, my most pressing problem is that the borders show up or go away depending on the scale.  See Doc1.docx
Thank you
Tags (1)
bobcostanza
Thanks for trying, if it turns out it’s the only imagery available for the area I will try again.
CodyBenkelman
Bob
sorry for the late reply - I just found this thread.  DId you resolve this?
What I believe will work is
1) build footprints so the image borders are clipped off when zoomed into (nearly) full resolution, then
2) rebuild all overviews (the reduced resolution views)
What you're seeing when you zoom out are overviews based on the current view when they're built.
But one note - you said you built footprints with minimum value of 75 - this should normally be 0, or near zero if you have imagery using lossy compression (JPG,  JP2, MrSID etc.).  If you use 75, I'd expect a lot of darker pixels (values below 75) around the edge of the images would get clipped out by the footprint, contrary to your intent...
Let us know if this is still an issue
Cody B
bobcostanza
Cody, I may revisit this problem but not soon. I'm hoping other imagery
will be found
