Is there a workaround to extract line features from a raster extent?
1519
03-13-2017 03:38 PM
deleted-user-sBBlTZilBs4n
I have a DEM that I want as my project extent. My vector features all extend beyond this DEM, so I want to clip/extract the vector features to the DEM. I’m using ArcMap 10.4
Thank you!
DarrenWiens2
Technically, you could just convert your raster to polygon and use that as the clip shape, however, you'll get one polygon per separate pixel value blob (connected pixels with same value), so it could get quite complicated.
A more reasonable method would be to Create Constant Raster, with exactly same cell size, snap raster, processing extent, and coordinate reference system as the DEM. This will make one rectangular pixel value blob exactly the size of your DEM. Then, convert the constant raster to polygon.
AbdullahAnter
Honored Contributor
How the features beyond  the DEM and you want to extract  it from DEM?
