Is there a way to use Google Earth to display contours in 1m?
462
09-21-2011 10:46 AM
GrahamMcCulloch
The DEM data from the USGS is in 30m sections but I need to make a contour map of a 5 acre parcel. Is there a way I can use Google data, or something else, to create contours of approx 1m? Using the 30m USGS data just averages out the contours and makes basically straight lines, but I need a more accurate representation of the ground surface.
Thanks.
michaelcollins1
Creating 1 m contours from 30 m data won't be accurate at all and would be misleading. I would say that the area needs to be surveyed.
MelitaKennedy
Esri Notable Contributor
You might check with the local state or county to see if they've acquired better resolution data (like LIDAR).
Melita
SimonKettle
If only DEM were made to a 1m resolution! Now that would be great!
Like Melita said check with the local authority in AOI and see if there is better data available through them. LiDAR would be excellent!
