Tele Atlas house number ranges: L_F_HNR vs. L_F_F_HNR fields (both with issues)
922
09-26-2011 01:18 AM
ThibautDelaere1
I'm building a custom address locator based on Tele Atlas data and the dual range address style.
I'm having a problem with the house number ranges. Two kind of fields are available: the L_F_HNR fields and the L_F_F_HNR fields. The first contain '-1' values, which give some nasty incorrect 100% match results: see attachment
The other fields do not contain -1 values, but some ranges have non numeric fields. Example: from '12B' to '24'.
Is there a way to filter out these problematic fields while building the locator? I don't want to alter the reference Tele Atlas data as I expect the locator to be able to deal with the common used Tele Atlas data as is.
A selection clause could only filter out some records with both left and right ranges having -1 values.
Can I add some rule in the address style xml to replace -1 values?
Any other ideas?
Thanks in advance,
Thibaut
