Is there a way to turn on snapping for the drawing tool?
1510
10-06-2016 07:23 AM
MatthewGross
The "snapping" tool seems to only be attached to the editor tool and I want to be able to label some important points on my shapefile.
AbdullahAnter
Honored Contributor
I think that you have a graphic draw and you want to snap feature in edit session. Isn't That?
as the following picture, you can convert your graphic to features and you can snap easily.
Robert_LeClair
Esri Esteemed Contributor
The snapping tool only works for geographic data not graphic data generated from the Draw Toolbar.  As mentioned above, you can convert graphics to features and then snap.
