Is there a way to queue and load multiple feature classes into a geodatabase
2124
03-04-2020 10:58 AM
OliverIshmael
We have a regular need to update feature classes within a geodatabase with new data. This takes the following approach:
   Open ArcMap
   Add the QA_ feature class
   Data Management Tools > Features > Delete Features
   Drag in the data you want to load from ArcCatalog
   Data Management Tools > General > Append
   Set Schema to NO_TEST
We repeat this process 20-50 times.
Is there a way to automate this?
Many thanks
JoshuaBixby
MVP Esteemed Contributor
If Python coding is beyond your reach, you can also use What is ModelBuilder?—ArcGIS Pro | Documentation.
Asrujit_SenGupta
Yes. Write a Python script and schedule it to execute every 30min (decide time based on your requirement) using Windows Task Scheduler.
One suggestion: If you are deleting all records from the feature class, use the Truncate Table tool. That will be much faster.
Truncate Table—Help | Documentation
JoshuaBixby
