Is there a way to prevent users from extracting data from a feature service in arcmap?
1773
08-29-2017 12:07 PM
DeanThompson
I created several feature service for a department in my organization, then I created a map on our internal portal. The aim is to allow them access to the data in this format but has all the functionality as if it were a shapefile, except I don not want them to be able to extract out or export the data. Is there a way to prevent this?
https://community.esri.com/community/gis/enterprise-gis?sr=search&searchId=3590dab3-7b06-4cfc-adb7-7...https://community.esri.com/community/gis/enterprise-gis/arcgis-for-server?sr=search&searchId=f519a19...
TimothyHales
Esri Notable Contributor
You would need to edit the Feature Access properties within the Service Editor. There is an Extract operation that you can disable.
Editor permissions for feature services—Documentation | ArcGIS Enterprise
DeanThompson
I already disabled that option. but in ArcMap, when I right-click on the service it gives the option to export data.
Asrujit_SenGupta
MVP Regular Contributor
No, any data which can be opened in ArcMap and the user has permissions to view, can be exported out as well.
Similar Posts mentioning the same info:
Restrict Data export
Feature Service Security...or lack thereof!?!
10.2.2: Disabling extracting digital data from services,
JayantaPoddar
MVP Esteemed Contributor
For the users you don't want to give the extracting capability, just share another Map Service (using an identical map document) with Feature Access capability disabled while publishing.
Think Location
