Is there a proper way to delete archived feature classes?
2190
03-02-2020 06:34 AM
MKF62
When I open my enterprise geodatabase and delete a feature class that participates in archiving, it gets deleted as expected. Then when I refresh that database, the feature classes reappears as "FeatureClassName_H". I assume the underscore H means "History" and that layer does indeed contain all the points that were archived, even if they were deleted somewhere along the way in the original layer. So after deleting the archived feature class, the _H feature class appears and then I delete that one too. Is there a proper process I should be using, or this the correct way to go about it?
Tags (1)
DanPatterson_Retired
Enable archiving—Geodatabases | Documentation
Disable archiving—Geodatabases | Documentation
the _H and several _ extensions can appear.
Sounds like disable and then decide what to do with remnants/history is suggested
I assume you experimented with the help topics in the Archiving and Versioned sections
eg
What is archiving?—Geodatabases | Documentation
eg
MKF62
Yeah, I wasn't disabling first. That helps. Thanks!
