Is it a bug? Editing non versioned data
1201
12-19-2013 01:41 AM
FulvioGiungato
Hi all,
I have a non-versioned FC called FC1
I load it into ArcMap as the only layer present in an MXD. I try to start an editing session and, as expected, the applications tells me that I have no editable layers.
I load another FC in the same mxd, it's called FC2. It's a registered as versioned  FC.
I start an editing session. I have no warning message because I selected the correct workspace I want to edit (the FC2 one).
Well, now I am able to change and save FC1 attributes(the non-versioned one), too. I am still not able to modify geometries.
I know that I am editing the base tables of FC1 (no delta tables becuase FC1 is not registered as versioned). I checked the results through SQLDEVELOPER and the base table has changed.
Is it a normal behaviour?
The platform is
SDE 10.1 SP1 in Direct Connection
Oracle 11g
ArcMap 10.1 SP1
AsrujitSengupta
Yes that behavior seems to be a known issue:
[ NIM091735 - In ArcMap in the Editor toolbar, the attribute values of a non-versioned feature class can be edited in an edit session even if versioning is enabled in the Editor options.]
http://support.esri.com/en/bugs/nimbus/TklNMDkxNzM1
FulvioGiungato
Thank you very much for the link
