Inserts in table not synchronizing
1227
02-28-2017 07:11 AM
NickKoopman
Hello All,
I've got a feature class of roads and a table of maintenance events on those roads. I have a relationship class linking the two in a 1-M relationship. The data is being housed on an Oracle database for internal use, and is also on a SQL Server database, which is used to serve up the data on ArcGIS Server for field crews to create the maintenance events using Collector.
I have two-way replication set up between the two databases. Modifications made to the feature class in SQL Server are synchronizing back to Oracle without issue. But any records added to the table of maintenance events are not. There is no error message in the synchronization log.
Any assistance on this would be appreciated.
