Importing shapefile to CAD- location off
2181
01-15-2014 05:38 AM
TracyDash
I'm having trouble importing a shapefile into CAD...I set the projection/coordinate system to exactly what the 'drawing settings' are in CAD but the shapefile doesn't come in to the right location: the coordinates are about 5 degrees off.
Unfortunately I can only control the shapefile side of the problem, not the CAD part. Any suggestions would be greatly appreciated!
Thanks.
JacobHaney
Importing a ESRI shape file into CAD is always difficult. Plain AutoCAD won't import Shapefiles, but AutoCAD Map/Civil3D will. Try installing third party Add-ons.
Using AutoCAD MAP to Import a SHP file of contour data and run a MAP Query to set the contour elevation properties.
