ImportError: No module named ExcelToTable
6878
06-13-2015 11:56 AM
AlbertClawson
System: Windows 8.1 64 bis, ArcMap 10.3.0.4322, Python 2.7.10150 which is installed in c:\python27
pythonpath=c:\Python27\ArcGIS10.3\Lib\site-packages
When I attempt to import data from an .xlsx file in the toolbox I get the following error as soon as the file dialog opens (before I even attempt to specify the filename)
file:///C:/Users/A/AppData/Roaming/esri/Desktop10.3/ArcToolbox/Dlg/MdDlgContent.htm#ERROR file:///C:/Users/A/AppData/Roaming/esri/Desktop10.3/ArcToolbox/Dlg/MdDlgContent.htm#
updateParameters Execution Error: Runtime error Traceback (most recent call last): File "c:\program files (x86)\arcgis\desktop10.3\ArcToolbox\Toolboxes\Conversion Tools.tbx#ExcelToTable_conversion.UpdateParameters.py", line 4, in File "c:\program files (x86)\arcgis\desktop10.3\ArcToolbox\Toolboxes\Conversion Tools.tbx#ExcelToTable_conversion.UpdateParameters.py", line 24, in updateParameters ImportError: No module named ExcelToTable
What exactly is missing and how can I correct this problem?
JayantaPoddar
Hi Albert,
Just a guess. Excel to Table was supported from ArcGIS 10.2 (Python 2.7.5) onwards.
Could you install the Python 2.7.8 that comes with ArcGIS 10.3 setup. Then run a repair for ArcGIS Desktop.
Let me know if the issue persists.
Think Location
JayantaPoddar
Hi Albert,
Think Location
AlbertClawson
I ended up uninstalling python and ArcGIS, rebooting, then reinstalling ArcGIS and now everything seems to be working fine.
curtvprice
Albert (or someone) please move this thread somewhere else, say  Managing Data​.  This place is for help on using the GeoNet website.
DanPatterson_Retired
Curtis...Done​
