Import Feature Class (Single) ERROR 999999
1289
11-27-2011 09:06 PM
AdrianBuddle
Hi All
Non-Administrator tutor here, trying to import a feature class to a File Geodatabase Feature Dataset within ArcCatalog, but getting an annoying and uninformative error every single time.
We're using ArcGIS 10.0, and just created a new geodatabase from scratch. It is the same coordinate system as that of the data - NZGD 2000 New Zealand Transverse Mercator.
When I go to import the data, it comes up with the error message:
ERROR 999999: Error executing function
The table name is invalid
A locator with this name does not exist
Failed to execute (FeatureClassToFeatureClass)
Anybody have some ideas as to how I can work around these problems?
Thanks
Adrian Buddle
JakeSkinner
Esri Esteemed Contributor
Hi Adrian,
What is the name you are specifying when you attempt to import the feature class?
ThomasCaspari
Hi Adrian,
I was wondering if you found a solution to this issue. I am having the same problem (same error, same coordinate system).
Have you been able to find a workaround?
Thanks
Thomas
JonDeRose
Thomas,
Would it be possible for you to attach a schema only copy of the feature class with instructions to replicate this behavior so we could take a look?
Jon
DavidEdwards1
Thomas,
Jon
Can you still look into this? I have the exact same error.  Thx. dave
