Import ECEF WGS84 BLH in Arcmap?
3898
6
07-05-2017 02:22 PM
Bjornten_Broeke1
I have a file in ECEF WGS84 BLH in meters with dd:mm:ssfor Angle Units.
I want these point to import in Arcmap 10.5 as point layer.
The file to import is a KML, with these points.
I can import them with KML to layer, I can see all the points, but I cant get them on the map in the right position.
Does somebody now a way how to get there?
Bjorn
Tags (3)
JayantaPoddar
Which area do the points belong to? Could you attach the KMZ file here so that we can review it?
Think Location
Bjornten_Broeke1
Its so far out of the world that it's lost. It is by the way a mistake from me, it should be CSV in my text, so Excel to layer I did, my mistake.
file_name,file_type,sequence_id,timestamp,GPS_time(s),ecef(x‌),ecef(y),ecef(z),at‌titude(x)=roll,attit‌ude(y)=pitch,attitud‌e(z)=pan,frame_id F:/DG_Paderborn-Borchen - Etteln_170620_Run1/2017-06-20_10-35-25/ladybug_panoramic_000‌000.jpg,JPG,0,285833‌39722,1181983021.108‌2721,3922148.9627709‌221,604199.614461860‌27,4976781.334698205‌8,-177.5736892226599‌7,7.1055832760669553‌,-79.315623440207304‌,1068
this is the header with one row with data, i am interested in mapping the ECEF(x) and ECEF(y) to a fitting EPSG code, or in some way getting it in. It should be in Germany, in the area Paderborn-Borchen area
JayantaPoddar
Could you attach a sample CSV for review?
Think Location
Bjornten_Broeke1
just emailed a example
JayantaPoddar
my email-id is [email protected]
Think Location
JayantaPoddar
Thank you for sharing the sample data. The method I am seeing is a bit tedious, but the task can be done.
I can do the conversion of ECEF (X,Y,Z) to LLA (Latitude, Longitude, Altitude) using Latitude/Longitude/Height ECEF via J-Script . I can perform one row at a time.
If I input the ECEF (X,Y,Z) in km, I get the result in Lat./Lon./Height.
Add the resulting of Lat./Lon./Height in the Excel sheet, and use Add XY Data to add points from the XY Table.
Note: Just use the values (e.g. 51.61909 / 8.75747 / 231.3) for Lat./Lon. and Height fields.
Think Location
