My issue is that the world geocoding service does not have the address I need to query.So this local runtime geodatabase was one solution I knew about. How can I create it or else what other solution to this problem is present. I am using ArcGIS Runtime SDK for Android for the development.
Are the addresses are for India or US?
I faced a similar issue where I was also using Single Field and it didn't work out as I was expecting it to. I had to change the Address Locator style to Gazetteer and it worked out for us.
Refer:
Commonly used address locator styles—Help | ArcGIS for Desktop
I hope this helps!
~Shan
Divya,
What address locator style are you using for creating the address locator?
~Shan
Refer:
I hope this helps!
~Shan
