I can't input two locations via coordinates on a map.
1420
10-30-2016 11:36 AM
KaylaniMendez
I'm trying to add two points on a map representing two sampling locations, but I don't know if I'm doing the .csv document correctly or the coordinates numbering or what, because the points are not showing up on the map. The coordinate system is NAD27 (USGS) but it doesn't specify anything else. Please HELP!
DanPatterson_Retired
csv format simplified
Easting, Northing
300000, 5025000
301000, 5026000
Note... no blank lines, simple headers without spacing and comma-separated.  Those coordinates are UTM-like, so just add it as xy data.  Once added, save/export to a shapefile or a featureclass in a geodatabase.  You should define its coordinate system appropriate for your zone.
