I am trying to import OSM .bz2 file using the Load OSM file in OSM Toolbox
5002
08-13-2014 03:52 AM
WilliamLuscombe
It is a large file as it is the world.
I am getting the following error:
Data at the root level is invalid. Line 1, position 1.
   at System.Xml.XmlTextReaderImpl.Throw(Exception e)
   at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
   at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
   at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
   at System.Xml.XmlTextReaderImpl.Read()
   at System.Xml.XmlReader.MoveToContent()
   at ESRI.ArcGIS.OSM.GeoProcessing.OSMToolHelper.countOSMStuff(String osmFileLocation, Int32& nodeCapacity, Int32& wayCapacity, Int32& relationCapacity, ITrackCancel& CancelTracker)
   at ESRI.ArcGIS.OSM.GeoProcessing.OSMGPFileLoader.Execute(IArray paramvalues, ITrackCancel TrackCancel, IGPEnvironmentManager envMgr, IGPMessages message)
Failed to execute (OSMGPFileLoader).
I believe that you this is the right tool but there does not seem to be a memory error.
Tags (1)
