I am trying to geocode addresses using 911 sites and an excell spreadsheet
1473
11-09-2014 04:21 AM
JonathanLax
My class project is to map out vacated properties in Providence, RI.  I want to be as accurate as possible, so I am building my address locator from 911 sites shapefile and then geocode the addresses from an Excel spreadsheet.  But I was having a lot of trouble loading the spreadsheet - its seems the connection between the folder where I am storing the spreadsheet and the map is broken!  What am I doing wrong?
StevenGraf1
Seems like a strange issue.  I would save your excel document as a csv in a folder that you already have connected inside ArcMap.
Steven
JonathanLax
Hello Steven - thanks for responding to my question.
Actually I have successfully created the address locator and joined the
data from my spreadsheet.
However, I got a huge number of mismatches: about half of the 1217
properties on the list!
I've manually trying to rematch those properties by checking the addresses
/ zip codes on google maps. That works occasionally - 14 of 55 attempts so
far.
But that means the Interactive Rematch is not finding correct / corrected
addresses / zip codes 41 times.
Its a terribly laborious process. Any suggestions? Do tell.
And my thanks for all you do!
Jonathan Lax
<compass.research.company@gmail.com>
Roger Williams University
School of Continuing Studies Community Development program
jlax315@g.rwu.edu <compass.research.company@gmail.com>
935-7877 <compass.research.company@gmail.com>
StevenGraf1
By 911 sites, I assume that's a point shapefile.  Did you create a general address locator from this?  Make sure the addresses in the 911 sites and excel document are formatted EXACTLY the same to get a good geocode.
Steven
