How to transform a layer from WMS to shape or KML?
4852
09-01-2015 02:29 PM
JoseCastillo
Dear community
I want to use some layers that are contained in the following WMS:
http://gaiga.inegi.org.mx/NLB/mdm5.wms
(Specifically the layers contained in the MGE group).
For that purpose, I need to convert these layers to shapefiles or to whatever format I can actually use, but I haven´t been successful at converting or exporting this information.
Does anybody know what can I do to convert this layers? Is there some kind of "trick" or method for that matter?
Thanks in advance
G
Samk
A bit late, but I have some ideas about that. Just today I tried a few: You can create a new map. Add the WMS that you need to the map, then in the tab Share of ArcGIS Pro (PC), select Export Map. It will open on the right side the exportation options in the section file type. You choose the format you need (SVG) and export the map using activate the option show preview and u could get some rasters, is not the best but its something instead draw all u can create diferent sections of svg then join all and map the raster. important note dont use a basemap if u try this. and i u use tiff set the options to color depth to 1 monocrome threshold 254.
