How to get Coordinates of several polygons (fishnet)?
7781
15
06-08-2017 03:04 AM
SophiNeuner
Dear all!
I created a fishnet  of a certain extend. See AlpineSpace layer. Now i want to clip all Polygons (Grids) out, that "touch" this layer. Here is the first problem, i don´t know how to to this. i just know how to clip with this .shp. Than i would like to know of each polygon the coordinates. I need it for the right top corner. I know that i could add the xy coordinates for the points, but i would need it for the top right corner of each polygon "touching" the AlpineSpace layer. If i use the "Feature Vertices to points" tool i don´t get the top right corner.
Does annyone know what i mean and how to do it?
Thank you!!
Bests!
SophiNeuner
Ah found it! First export as table and add it.
SophiNeuner
Thank you, you helped me so much.
But are now the max x and y coordinates the coordinates of my point feature layer?
XanderBakker
Esri Esteemed Contributor
If you followed the instructions and used the max X and max Y coordinates to create the points, you will have points that represent the upper right corner. Remember to export the XY events layer to featureclass to create a featureclass. The events only exist in the session of ArcGIS.
I will have a look at the ZIP you attached just to be sure.
XanderBakker
When you attach a shapefile, remember that the shapefile consists of multiple files. See Shapefile file extensions—Help | ArcGIS Desktop . You will have to ZIP at least the .shp, .shx and .dbf file. Best is to include all the "Merra_cutting_asa.*" files.
BlakeTerhune
MVP Alum
ChrisCatania
Esri Community Team
Hi Sophi - Thanks for asking your questions and welcome to the GeoNet community! I wanted to let you know that we're moving your question to the https://community.esri.com/community/gis/managing-data?sr=search&searchId=21e5f542-2f84-4ccd-905c-23...‌ space so our Esri and user subject matter experts can further help answer this and future questions.  So you're aware on how and where to post your questions, here's a few quick tips and reminders:
  • First, use the GeoNet search (top right corner by your profile icon) to search and see if your question has already by asked/answered previously.
Thanks again for contributing and I hope this helps and let us know if you have any questions.
