How to fix Mosaic Dataset extent
1770
10-24-2013 11:43 AM
AnthonyPagan
I created a new raster mosiac dataset and it had a bad image and the entire county would show up in the upper right hand corner or my screen and the one bad image in the bottom left I did a search on how to remove an image did it and continued to follow instructions on how to delete and fix foot prints, boundary and over views but it still shows up in the upper right hand corner of my screen. It has the correct projection. How do I fix the extent of the mosaic.
JakeSkinner
Esri Esteemed Contributor
Hi Anthony,
In the catalog tree, right-click on the mosaic dataset > Properties > Feature Extent tab.  You can click 'Recalculate' or manually set the extent.
AnthonyPagan
Thanks KSkinn3 for the advice but it didn't work but I figured it out I had to delete the boundary and rebuild it and it worked fine.
