How to cut a 3d raster dem file ?
5241
07-05-2012 07:28 PM
marieetchebes
How to cut a raster dem file ?
I would like to trace a line on the 3D raster surface, then cut the surface along this line. At the end, I want to be able to move each part of the 3d surface independantly.
Do you think I can do it with ArcGIS?
thanks for your help
Md__AbulHayat_Chowdhury
Hello,
I think you can use "mask" for cutting any dem but of course you need one/two/....... polygon, which area you want to cut.
Thanks
Hayat
KONPETROV
with which tool can i do that?
KishorGhatage
1. Use Interpolate shape tool. This tool extracts the raster values and assign to line.
http://resources.arcgis.com/en/help/main/10.2/index.html#//00q90000006m000000
2. Now use Split line at vertices tool.
http://resources.arcgis.com/en/help/main/10.2/index.html#//00170000003z000000
3. Then Use the splited line as input  in Feature to Point tool (point_location = Centroid)
http://resources.arcgis.com/en/help/main/10.2/index.html#//00170000003m000000
4. Finally use Extract by points tool to extract the pixels below the line.
http://resources.arcgis.com/en/help/main/10.2/index.html#//009z0000002p000000
