How to clip map sheets to a Map Gird
4769
11
02-03-2017 11:17 AM
JosephPlessis
I have multiple geo referenced scanned maps from the 1950's, Like 60 of them.
I need to clip some white space off the edges so I can apply a fishnet.
So the main question is I have a 50k nts grid where the maps sit perfectly within each grid tile, When i try to clip the map to the grid it does nothing because it is reading the outside border of the nts grid. how would i get the clip to read each individual grid tile for a clip?
thanks
DarrenWiens2
Have you tried select (the grid polygon), then clip?
JosephPlessis
I did selct a grid portion and created a layer form selcted data then proceeded to do the clip.
Your way sounds easier.
Is there a way to script this for I have a lot of maps to do.
DarrenWiens2
Yes, you could certainly do this with a Python script, looping through rasters, calculating raster centroid from extent, selecting the grid cell covering the centroid, doing the clip.
JosephPlessis
is there any good resources to script this
DarrenWiens2
Start at the following link, get started on your script, and then post it back here when you need more help.
What is ArcPy?—ArcPy Get Started | ArcGIS Desktop
Basically, figure out the geoprocessing tools you need, find and use the Python syntax on each tool's help page, and then put it in a for loop to repeat. But, first you need to figure out some Python.
NeilAyres
But if these are scanned map sheets, why not load them into a mosaic, then use the map polygon grid as the footprints.
This will auto magically leave behind all the stuff around the edge.
JosephPlessis
I like this idea!
So after i could split aprt the mosiac using split raster?
AbdullahAnter
Honored Contributor
Prefect Answer,Neil Ayres Champion . It is it
JosephPlessis
so far i have this but no return on my clip
import arcpy
# Set the current workspace
arcpy.env.workspace = "Q:\\josephplessis\\GIS 307 Resource Managment\\Project\\Mapsheets\\soil"
#variables
R1 = "102I16"
R2 = "102I09"
R3 = "102I08"
R4 = "092L13"
R5 = "092L12"
R6 = "092L11"
R7 = "092L10"
R8 = "092L08"
R9 = "092L07"
R10 = "092L06"
R11 = "092L05"
R12 = "092L04"
R13 = "092L03"
R14 = "092L02"
R15 = "092L01"
R16 = "092E16"
R17 = "092E15"
R18 = "092E14"
R19 = "092E10"
R20 = "092E09"
R21 = "092E08"
R22 = "092E07"
# Local variables:
Output_Raster ="Q:\\josephplessis\\GIS 307 Resource Managment\\Project\\Geodatabases\\Grid_points.gdb\\gridlist.tif"
gridlist= R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12,R13,R14,R15,R16,R17,R18,R19,R20,R21,R22
grid="Q:\\josephplessis\\GIS 307 Resource Managment\\Project\\Geodatabases\\Grid_points.gdb\\GRID"
arcpy.MakeFeatureLayer_management(grid, "gridlyr")
arcpy.SelectLayerByAttribute_management("gridlyr", "NEW_SELECTION", " NTS_SNRC = 'gridlist' " )
print gridlist
# Get and print a list of TIFs from the workspace
rasters = arcpy.ListRasters("*", "TIF")
for raster in rasters:
print(raster)
while raster==gridlist:
arcpy.Clip_management("raster", Output_Raster, "gridlist", "", "", "NONE", "NO_MAINTAIN_EXTENT")
