How do you stop duplicate data in a feature class from being created?
1839
09-04-2012 04:51 AM
TimLangner
Hi there
I may have asked this before but I'll ask again since 10.1 is now out.
I have a feature class with over 65,000 rows of data. This is stored in ArcSDE 9.3.1, hosted in Oracle 10gr2. I am using ArcMap 10.0.4 myself.
Each row should have a unique feature id. Sometimes features need to be split into two and what I have now found, having done a distinct query on a copy of the feature class in SQL Developer, is 26 rows of duplicated ids.
Is there anyway to stop this from occurring? In Oracle itself I can simply apply a unique key constraint but I've yet to find anything in ArcMap or ArcSDE to stop this from occurring. Is their anything available.
Kind regards
Tim
VinceAngelo
Esri Esteemed Contributor
You need to handle the split operation for external constraints, of which ArcGIS
has no knowledge. A unique key constraint would prevent you from editing in a
versioned environment, and wouldn't solve the id split issue, so you need either
application code or a trigger (the latter can be risky if you don't handle valid
duplicates [aka versioned edits] correctly).
- V
TimLangner
Thank you for your reply vangelo. I'm not looking to do anything risky. I was just looking to do it all within the safe boundaries of ArcGIS itself.
I assume from your comments that it is not possible. I have now upgraded to 10.1 and I get the impression it isn't possible in that either.
Kind regards
VinceAngelo
Parcel splitting is a common enough task, but you need to use tools which are aware
of the problem.  A google on 'arcgis parcel splitting' returns what appears to be a
number of ways to address the issue.
- V
TimLangner
Thank you for your reply. I had not thought of using any of the land parcel tools. The data set I am working with is a record of features that are maintained. For example grass; flower beds; roads; pavements and so on. I've generally been spiting and merging polygons via digitising the split line for a split or selecting the require polygons and merging them.
Then I would manually change the ID numbers to assign a new one or I would note the unused number and assign it else where to remove id number gaps. I only do this because the process is manual.
Kind regards
