How do you automatically timestamp new and edited records in an SDE feature class?
10391
18
05-04-2010 02:38 PM
SharonMitchell
I would like to make it so that as a feature class is edited the "modifiedDate" and "user" fields will be updated automatically. Is there a way to do this?
SrijanaTuladhar
I just enable editor tracking in the feature class, I noticed that in the LAST_EDITED_DATE field, the current time is incorrect (the date is correct though). Did any of you have the same experience? Thanks!
MichielStaessen1
Message when enabling editor tracking clearly states that dates are stored in UTC (as they should be!)
VinceAngelo
Esri Esteemed Contributor
Is the system date on your client workstation correct?
- V
SrijanaTuladhar
Yes, we're in the Eastern time, but it records the Pacific time. Also when I query the current timestamp from the oracle database, it shows the correct timestamp.  Thanks!
VinceAngelo
In which timezone is your server?
Are you using an application server connection, or Direct Connect?
- V
SrijanaTuladhar
- V
Our server is in Eastern time zone. Please see below. We're using an application server connection. Thanks!
-bash-4.1$ date
Fri Oct 26 11:51:56 EDT 2012
VinceAngelo
Do you have the TZ environment variable set explicitly on both the Windows Desktop
host and the database server?  Without an explicit TZ, there's a great deal of room
for interpretation.
- V
SrijanaTuladhar
for interpretation.
- V
It does not seem like we have TZ enviroment variable set up. Could you tell what we need to set up? Thanks for your help!
VinceAngelo
This is complicated enough that you really need to research it yourself to be sure you know
what happens is what you want to hapen.  A google on "tz oracle variable" will get you started.
If you were using Direct Connect I doubt this would be an issue.
- V
