How do you automatically timestamp new and edited records in an SDE feature class?
10368
18
05-04-2010 02:38 PM
SharonMitchell
I would like to make it so that as a feature class is edited the "modifiedDate" and "user" fields will be updated automatically. Is there a way to do this?
SharonMitchell
Editor Tracking worked perfectly. Thank you!
RicFritz
Has anyone updated the EditorID application to run in Windows 7?
Thank You,
Ric Fritz, GISP
GIS Technology Manager
Citrus County Property Appraiser's Office
352-341-6665
[email protected]
BrianZwilling
Is anybody aware of any arcgis 10 updates for editor tracking?
JeffLedbetter
I'll add my voice to the chorus of people looking for version 10 updates to either EditorID or Editor Tracking!
luiscorea
So do I. I don't understand why this tool is still not integrated with arcgis using SDE geodatabases. Please is any tool/script available to do the same for 10, that will help me a lot.
Lake_Worth_BeachAdmin
You can use it for SDE databases, my organization does.
DerekLaw
Esri Esteemed Contributor
All,
Please see this thread on a similar topic, specifically Craig G's post:
Hold on Date and User when Editing
Hope this helps,
nicogis
you can create a class extension in 10 (10.1 has included this functionality) .
Here you can see Timestamper class extension
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//0001000003ps000000
1) compile this solution with vs2010.
2) Register dll with esriregasm
3) open arccatalog and create a feature class
4) select type class 'TimeStamper class'
5) select type of feature class (polygon, point ect)
7) add your fields of feature class
6) in feature class you have a new tab (Timestamp Settings) where you can set field created, filed updated and field user (you can also set 'not used')
For local geodatabases, user is the username as known by the operating system (in a domain\username format). For remote geodatabases, the IDatabaseConnectionInfo interface is utilized.
