How do I unlock a secure geodatabase?
2672
08-21-2011 04:33 PM
OlufisolaOladipo1
I have some gis data in file geodatabase format. The data was saved in pmf format.
All I want is to have access to the data so I can edit and manipulate.
Right now I can see the data only through arcreader. I have tried to uncompress the data but it did not work. When I try to view it in arcmap or arccatalog, it will give " secure data", no access.
Could someone help. I need help urgently.
JoeBorgione
You need to have who ever actually owns the data to give it to you.  First you state it's a geodatabase, but then you say it's in pmf.  So which is it?  If you have a geodatabase on your computer, you should be able to set the permissions so you can edit it.  If you are simply hacking a database, you are on your own.
