from .EPS (or FH10) to .SHP
2980
08-21-2011 12:02 PM
MicheleValsecchi
I have some maps in .EPS (as well as .FH10) format which I would like to import to ArcGIS either as shapefiles (preferred) or raster.  Any idea on how to do it?
I read I could do this by opening the files with Macromedia Freehand (or Adobe Illustrator) georeference the files with MAPublisher and export them as .SHP to ArcGIS. However, so far I failed to do it.
Thank you in advance for any help,
Michele
JonWebb
I used to do this quite a lot. However I didn't manage from Freehand. I would get the data into CorelDraw or Canvas and export as dxf. Then import the dxf to ArcGIS and use spatial adjust to get it into position.
