How do I get a street name corrected?
2066
01-31-2024 07:21 AM
JoelBreazeale
I have a simple Python application to illustrate an issue:
#!/usr/bin/python3.9
import geocoder
g = geocoder.arcgis('1286 County Road A, Deer Park, WI 54007')
print(g.json)
The output is:
{'address': '1286 County Road a, Deer Park, Wisconsin, 54007', 'bbox': {'northeast': [45.222714980538, -92.423393031944], 'southwest': [45.220714980538, -92.425393031944]}, 'confidence': 9, 'lat': 45.22171498053788, 'lng': -92.42439303194378, 'ok': True, 'quality': 'PointAddress', 'raw': {'name': '1286 County Road a, Deer Park, Wisconsin, 54007', 'extent': {'xmin': -92.425393031944, 'ymin': 45.220714980538, 'xmax': -92.423393031944, 'ymax': 45.222714980538}, 'feature': {'geometry': {'x': -92.42439303194378, 'y': 45.22171498053788}, 'attributes': {'Score': 100, 'Addr_Type': 'PointAddress'}}}, 'score': 100, 'status': 'OK'}
This is merely cosmetic, but the 'a' in 'County Road A' is lowercase.  It should be uppercase.  I have a few others like this.
How can I contact the right person to get this corrected?
Tags (1)
MErikReedAugusta
MVP Regular Contributor
Are you asking how to correct it via Python, or how to correct the underlying data?  Because the latter is almost certainly beyond the scope of this forum, but the short version is: It depends on who's responsible for the underlying data.
If you're asking how to fix it via Python, there are a number of ways with regular expressions and the like, but with most of the road names I've seen throughout the country, there's a pretty good likelihood you'll get false positive results of things changing that you didn't intend, unless you're very careful with the script.
When and how you make a correct via Python also depends on your end goal/use of the data.  What do you intend to do with the geocode data once you have it?
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
JoelBreazeale
I am using ArcGIS as a geocoder.  I was asking about correcting the underlying data.
Raul
You could use the string.title() function to assign capitalization to each of the json keys you want.
For example, using
data = g.json
data['address'] = data['address'].title()
data['raw']['name'] = data['raw']['name'].title()
yields
{'address': '1286 County Road A, Deer Park, Wisconsin, 54007', 'bbox': {'northeast': [45.222714980538, -92.423393031944], 'southwest': [45.220714980538, -92.425393031944]}, 'confidence': 9, 'lat': 45.22171498053788, 'lng': -92.42439303194378, 'ok': True, 'quality': 'PointAddress', 'raw': {'name': '1286 County Road A, Deer Park, Wisconsin, 54007', 'extent': {'xmin': -92.425393031944, 'ymin': 45.220714980538, 'xmax': -92.423393031944, 'ymax': 45.222714980538}, 'feature': {'geometry': {'x': -92.42439303194378, 'y': 45.22171498053788}, 'attributes': {'Score': 100, 'Addr_Type': 'PointAddress'}}}, 'score': 100, 'status': 'OK'}
JoelBreazeale
How I can the data corrected at the source?
CharlesShaw
Hi Joel,  Did you get any response for your inquiry?   If you did, could you post what you found out because I'm curious as well.
