How do I disable the ' You are changing the subtype for this feature.' pop-up window?
2849
11-02-2011 07:12 AM
Kevin_Sieger
ArcMap (ArcGIS 10) has a window that pops-up whenever the default subtype is changed for a feature that asks me if I want to change it.
How do I disable it?
by Anonymous User
Not applicable
You can toggle this behavior with the advanced arcmap settings utility.
Run this from the \ArcGIS\Desktop10.0\Utilities directory and select the editor tab in the dialog.
Toggle the 'warn on subtype change' checkbox as required.
Kevin_Sieger
Thank you so much!
Do you have any other change settings, tips and tricks, etc that you can tell me about?
by Anonymous User
Not applicable
Take a look at the following ArcGIS Desktop blog. We did a series on editing tips and tricks which included information from the user conference technical session.
