Importing ???Raster Datasets??? to a geodatabase affects the ???clarity??? of the image.
1466
11-02-2011 10:05 AM
by Anonymous User
Not applicable
Original User: [email protected]
Importing �??Raster Datasets�?� to a geodatabase affects the �??clarity�?� of the image.
Please, see the attached screenshots that show my question.
I imported two images to my geodatabase but their clarity gets �??bad�?�.
What might be the problem?
How to import the images so that they stay clear as they are? Please, see the attached screenshots.
Thank you in advance,
Regards
Jamal
by Anonymous User
Not applicable
Original User: mharlow
It looks like it might be related to statistics. Right-click the layer in ArcMap, and click Properties. One the Symbology tab, change the stretch to NONE.
If this is the issue, then just remove the statistics from the image in your geodatabase. Right-click it in ArcCatalog or the Catalog window and click Properties. On the General tab, scroll to the Statistics. Click the Options dropdown arrow on the right and select  the option to Clean Statistics.
