How can I find a shapefile of all restaurants and bakeries in California? Or a free list of addresses to Geocode?
15143
37
04-16-2015 09:08 AM
MelissaTraverso1
New Contributor II
Hi I am currently trying to search for restaurant (of all types) and bakeries in California. I am thinking finding a shapefile of this is pretty unlikely but was wondering where I might find a free comprehensive list of addresses that I could then geocode within arcmap? Can google maps or google earth provide this for me?
Melissa
Tags (1)
MelissaTraverso1
New Contributor II
I also did not create a local copy on ArcGIS desktop and sync it with my ArcGIS online.
RakeshSinha
Okay... Once you edit the results in CA, it asks you to re-save the layer with a name. Use a different name there (something not used earlier) as the previous layer exists in CA My Contents > My layers > Business Points (NOT in AGOL) and would not let you save with the same name. Unless you have the layer you wouldn't be able to edit the results. I hope this makes sense.
MelissaTraverso1
New Contributor II
Hi Rakesh, If I am understanding you correctly I believe I tried this. I renamed my layer in the Community Analyst tool to for example VENTURA instead of Restaurants_Ventura. I then shared the layer with my ArcGIS online account. Went to VENTURA to publish the feature layer to a feature service and it gave me the same error message
RakeshSinha
I just tried the same at my end and it worked just fine for me.
MelissaTraverso1
New Contributor II
Interesting I have kept trying and it won't let me. When it says item with the same "key" what is this referring to?
Melissa
MelissaTraverso1
New Contributor II
Is anyone familiar with R? R apparently has several "packages" that include functions purpose-built for extracting data from Google Maps. The big one is called "ggmap" and "ggplot2". Wondering if I might be able to extract lat long points from this directly in order to create a shapefile.
Melissa
nimitz
An even better dataset (shapefile, GEODB, or whatever format) is a list of all the donut shops in the greater Sacramento region!
ChrisSmith7
I read through the forum postings and didn't see a mention of infoUSA (paid service):
Restaurant Database | Restaurant Mailing Lists | InfoUSA
They should already have the addresses geocoded; there may be license/usability constraints on the data, however. You'd have to inquire for more information.
I know you asked for a free resource, but just wanted to make you aware in case you were unsuccessful in this venture.
