Highlight field in attribute dialog for easy editing.
2445
08-11-2010 10:11 PM
GrahamW
I have found one of the most simple greatest inventions..
If you can't tell its Blu-tac
Just don't ask me about my white out tool!
RhondaGlennon
Nice. Well, for those on ArcGIS 10, there is built-in functionality to do this. Open the Layer Properties dialog box > Fields tab. Click the field and set the Highlight property to Yes. This will make it stand out in places like the attribute table and the Attributes and Identify windows.
ChrisHalcomb
Rhonda, can you change the highlight color?
RhondaGlennon
Currently, it is only yellow. You can contact Esri Support or post this enhancement suggestion at ideas.arcgis.com.
TimSpivey
Also available, by default I believe, in ArcGIS 9xx
