hi,i am very new to database connections.i am creating direct database connection with oracle 11gr2 with arcmap 10.3.but it fails to connect database and show below error.
3323
19
02-20-2016 12:02 PM
VaidhyPanday
AsrujitSengupta
Regular Contributor III
The connection string is incorrect.....you spelt your database name as 'MAYLAPPY' instead of MYLAPPY !
VaidhyPanday
sorry ,
i changed and checked but still getting same error
AsrujitSengupta
Can you just login from SQLPlus and post a screenshot of that. Don't post your passwords!
VaidhyPanday
AsrujitSengupta
I was talking about SQLPLUS in cmd, but anyways, ArcGIS Desktop being a 32-bit application needs a 32-bit Oracle Client. You mentioned that you have both the 64-bit and 32-bit Oracle Client installed....so this should not be an issue.
Just try these strings and check if it makes any diff:
  1. I.P_Address_of_your_lappy/MyLappy
  2. Server_name/MyLappy
VaidhyPanday
i tried all the combinations... servername/servicename
AdrianWelsh
MVP Honored Contributor
I am not sure if this was addressed or not but have you installed the Oracle 11g client?
Oracle Database 11g Release 2 for Microsoft Windows (x64)
VaidhyPanday
yes.
i have installed 11gr2 release oracle client
JamesGough1
ArcMap is a 32-bit application and you need to install the 32-bit version of Oracle client drivers like Oracle Instant client.
Then you need to add both the 64-bit and 32-bit oracle clients in your system path.  64-bit path first and followed by the 32-bit Oracle bin in the path.
You need to re-start ArcMap before attempting to connect so it can pick up the updated path variable.
I can work with you on this in a meeting.
You can contact me at jgough@esri.com.
Hope this helps.
Thank you,
  Jim Gough.
Thank You,
Jim Gough | Technical Lead Enterprise - Educational Services
Esri
VaidhyPanday
Thnaks sir,
now i am able to connect database.
