Global IDs and Replicas Question
1159
06-17-2014 07:10 AM
TimHayes
I am using ArcGIS for Desktop 10.2.2 and SQL Server 2008 R2.
SITUATION:
Here is what I have:
- Geodatabase A - deleted and removed.
- Geodatabase B - new name, new instance, contains the data copied from Geodatabase A.
- One-Way Replica (Parent to Child) X - is still registered to the Geodatabase A.
I try to unregister Replica X and reregister it with Geodatabase B, but under Replica Manager when I attempt to unregister it, I get the message "Replica could not be deleted, access denied".
QUESTIONS:
It is possible to reregister a Replica with Geodatabase B? Will this change the Version as well?
Do I need to delete the GlobalID Attribute Column in each Feature Class and then create new GlobalIDs?
I tried to create brand new Replica, different name, registered to Geodatabase B, but I am denied the permission to do this as well.
What do you recommend I do in this situation?
